Configure an ARP proxy to allow the platform to answer a local ARP request for a remote destination. ARP proxy is disabled by default.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
ip arp-proxy enable
Use the no operator to disable ARP proxy: no ip arp-proxy [enable]
Enable ARP proxy on VLAN 200:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 200 Switch:1(config-if)#ip arp-proxy enable
